Hi there,
I just purchased a used X w/ about 19k miles and now I am starting to suspect that the clutch is on its way out. When cruising in 3rd, 4th, or 5th gear and getting into boost, the RPMs blip slightly (500 to 750rpm) before coming back down to normal and the car accelerating normally.
I have no idea how the car was driven previously, but it's in great shape otherwise.
After looking through some of the other threads and other forums, I found that there could be a rear main seal issue causing the clutch to slip or it could just be wearing out.
I need to know what the normal mode of failure is when the clutch wears out. Also, if anyone here has had rear main seal issues, how did that manifest itself in terms of clutch feel? (I will be checking for any sort of oil residue around the bell housing as well)
