I have worked out there is an issue with the installer and windows 10 not being able to direct the path for metadata, colour maps, logs and rom file directory. Of which there are no files in those folders which may be causing my next issue I cant view, edit my ROM as there are no definitions
[22:06:04.351] Logging to file C:/Users/Nathan/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20170314t220604.txt [22:06:04.351] EcuFlash Version 1.44.4799
[22:06:04.351] OS Version Windows 10
[22:06:04.351] Kernel Type winnt
[22:06:04.351] Kernel Version 10.0.14393
[22:06:04.351] CPU x86_64
[22:06:04.351] Product Name Windows 10
[22:06:04.351] Product Type windows
[22:06:04.351] Product Version 10
[22:06:04.351] Qt Version 5.6.0
[22:06:04.351] Qwt Version 6.1.2
[22:06:04.351] QwtPlot3D Version 0.2.6
[22:06:04.351] Boost Version 1.60
[22:06:04.351] FTDI Library Version 3.02.11
[22:06:04.351] Openport J2534 Library Version 1.02.4798
[22:06:04.356] 67 memory models read.
[22:06:04.356] scanning for metadata models in C:/Users/Nathan/Desktop
[22:06:04.357] 0 ROM metadata models scanned.
[22:06:04.357] checksum module "subarudbw" loaded.
[22:06:04.357] checksum module "subarudiesel" loaded.
[22:06:04.357] checksum module "subaruhitachi" loaded.
[22:06:04.357] checksum module "mitsucan" loaded.
[22:06:04.357] checksum module "mitsuh8" loaded.
[22:06:04.357] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[22:06:04.357] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[22:06:04.361] flashing tool "wrx02" loaded.
[22:06:04.363] flashing tool "wrx04" loaded.
[22:06:04.365] flashing tool "sti04" loaded.
[22:06:04.367] flashing tool "sti05" loaded.
[22:06:04.369] flashing tool "mitsucan" loaded.
[22:06:04.369] flashing tool "mitsukernel" loaded.
[22:06:04.369] flashing tool "mitsukernelocp" loaded.
[22:06:04.369] flashing tool "mitsubootloader" loaded.
[22:06:04.369] flashing tool "shbootmode" loaded.
[22:06:04.369] flashing tool "shaudmode" loaded.
[22:06:04.371] flashing tool "subarucan" loaded.
[22:06:04.372] flashing tool "subarucand" loaded.
[22:06:04.374] flashing tool "subarubrz" loaded.
[22:06:04.376] flashing tool "subaruhitachi" loaded.
[22:09:47.727] deleting current metadata
[22:09:47.728] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates
[22:09:47.733] 18 ROM metadata models scanned.
[22:10:58.440] using metadata XML ID read_mitsum32186f8 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8.xml
[22:10:58.445] using metadata XML ID read_mitsum32186f8 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8.xml
[22:14:00.282] using metadata XML ID read_mitsum32186f8 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32186f8.xml
[22:14:00.301] J2534 API Version: 04.04
[22:14:00.301] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[22:14:00.301] Device Firmware Version: 1.16.4769
[22:14:00.301] Device Serial Number: TAkuy3nl
[22:14:06.133] -- loading kernel --
[22:14:06.133] -- connecting to kernel --
[22:14:06.133] kernel get version
[22:14:06.458] ECU HW part number : 1860A982
[22:14:06.483] ECU SW part number : 1860A98201
[22:14:06.503] VIN : JMFSMCZ4A9U000339
[22:14:08.131] -- unlocking ECU --
[22:14:08.131] starting session...
[22:14:08.479] requesting seed...
[22:14:08.485] sending key...
[22:14:08.829] -- uploading kernel --
[22:14:08.854] .
[22:14:08.867] .
[22:14:08.879] .
[22:14:08.893] .
[22:14:08.905] .
[22:14:08.918] .
[22:14:08.933] .
[22:14:08.944] .
[22:14:08.957] .
[22:14:08.970] .
[22:14:08.983] .
[22:14:08.996] .
[22:14:09.008] .
[22:14:09.022] .
[22:14:09.036] .
[22:14:09.047] .
[22:14:09.060] .
[22:14:09.074] .
[22:14:09.086] .
[22:14:09.099] .
[22:14:09.109] .
[22:14:09.109] -- connecting to kernel --
[22:14:09.109] kernel get version
[22:14:09.114] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[22:14:09.114] reading kernel comm buffer size
[22:14:09.115] comm buffer size set to 1024
[22:14:09.115] reading kernel flash buffer size
[22:14:09.117] flash buffer size set to 4096
[22:14:09.123] -- dumping ECU memory --
[22:14:09.132] kernel read area: addr: 00000000 len: 0400
Removed rest for post
[22:14:44.235] -- connecting to kernel --
[22:14:44.235] kernel get version
[22:14:44.239] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[22:14:44.239] reading kernel comm buffer size
[22:14:44.241] comm buffer size set to 1024
[22:14:44.241] reading kernel flash buffer size
[22:14:44.243] flash buffer size set to 4096
[22:14:44.247] -- unloading kernel --
[22:14:44.247] kernel reset
[22:14:46.248] gathering info
[22:14:46.367] ECU HW part number : 1860A982
[22:14:46.393] ECU SW part number : 1860A98201
[22:14:46.403] entering programming mode
[22:14:47.909] -- unlocking ECU --
[22:14:47.909] starting session...
[22:14:47.925] requesting seed...
[22:14:47.936] sending key...
[22:14:51.124] -- reading ECU ID --
[22:14:51.647] ECU HW part number : 1860A982
[22:14:51.672] ECU SW part number : 1860A98201
[22:14:51.692] VIN : JMFSMCZ4A9U000339
[22:15:03.215] interface close
[22:15:03.217] interface close
[22:15:14.032] 1048576 byte image written.
[22:15:14.032] 0 byte image written.
[22:15:20.381] uploading b39ee0bd_M32186F8_mitsucan.srf to
ftp.tactrix.com for analysis...
[22:16:06.925] using metadata XML ID from file /
